Need a good alignment specs for 944 turbo
Hi,
I am going for a new alignment next week for my 86 turbo.
Things I have done this winter :
1. 250 Coil Springs for the front Weiltmaster
2. All 4 yellow koni sports
3. Lowering the back
4. 951 fuchs with Dunlop z1 tires (225 all around)
This is a street / once a week de car (for a small track). I might go to a big track only once this summer.
I need some good alignment specs to give to the garage for a new alignment.
Does anybody have something to recommend.
tires and your amt of street vs track time make a difference- i used to run alot of camber on my turbo but it was mostly track. My spec car is 3.5 neg camber front and 2.5 neg rear with max castor and just a touch toe in on the rear. I would say for a street track compromise like 1.5-1.75 front and 1 neg in in the rear with max castor and aligned straight should be ok - could bump the front and rear in to 2 and 1.5 if your feeling more aggressive.
