Horn beeps on left hand turns!
Old 03-07-2013, 05:55 PM
Fara
Fara's Avatar
Sorry bro, your car was just a bit pissy with you for forgetting valentines day AGAIN this year.
Old 03-08-2013, 03:59 AM
Butters944
Today I got
My Custom Title
Butters944's Avatar
Location: Las Cruces NM (NMSU) / Fountain Hills AZ (home)
This picture is finally relevant for something
Old 08-21-2016, 12:03 AM
greg.czika
2nd Gear
greg.czika's Avatar
I had the same problem as the person who started this post. I have an '87 944 Turbo with airbags.
My horn would honk when making left turns (especially in hot weather). The left horn button was also very sensitive. The lightest touch would sound the horn.
This other Rennlist post helped me find the culprit. Follow the instructions towards the bottom of this other post. Pictures are included:
https://rennlist.com/forums/928-foru...n-buttons.html
After ,removing the horn button, I found that the copper contact plate had become dislodged in the housing, so it was flopping around and making electrical when making left turn.
Old 08-21-2016, 10:40 AM
Voith
Voith's Avatar
Make sure your horn fuse is the correct amperage. I had audi that set itself on fire because of horn lead touched the wheel column and fuse didn't burn out so instead wire loom under dash set itself on fire.
Quick Reply: Horn beeps on left hand turns!
