Sway bar question
Sway bar question
When you measure the rear sway bars with a pair of calipers are they slightly oversized? Ie. 16.3mm measured = the 16mm bar, the 18.3mm = the 18mm bar and 19.3mm = the 19mm bar?
The reason I ask is because I just got an 18.3mm bar which was sold as a 19mm. I'm wondering if this could be a mistake or if it actually is a 19mm and the bars vary that much in diameter?
Rainman
my 18mm bar measures 17.8mm between the center hump and the curve to the wheel. i had a 19mm bar recently and it was visibly larger.
does your bar have just one hole on the end? 19mm will have either 3 or 5 holes on the end for adjustability.
It only has one hole either end, but I was told by the seller that this was a 19mm bar which was a special order from Porsche when the donor car was new. I assume this must have been before they made the 19mm 3-hole adjustable bars for the 968.
Nevertheless, I still think I've been sold a standard 18mm bar due to a misunderstanding. Do the bars have identification numbers stamped on them somewhere?
