Bolt and nut sizes?
Bolt and nut sizes?
Does anyone know where I can get a list of the various nut and bolt sizes used on the 944/951?
Off the top of my head I think 10, 12, 14 and 17mm sockets and spanners get the most use, but I'm just thinking about getting some ratchet spanners and thought I might as well miss out any sizes I'm not going to use...
So, you mean the head size, and not the thread size?
You can do most everything on that car with: 8mm, 10mm, 13mm, 15mm, 17mm and 19mm (wrenches (spanners) and sockets). Also you'll use 12mm to bleed the coolant and, if it has brembo calipers, 11mm to bleed the brakes. 7mm to bleed the clutch.
You'll also want a nice set of allen wrenches 4mm, 5mm, and 6mm are common sizes (17mm to change the tranny fluid). You should also have a triple square for the CV joints (I forget the size). A selection of screw drivers, and an oil filter socket. And a pair of good size adjustable pliers for squeezing brake cylinders back in when you change pads.
I'm also a big fan of magnetic pickup tools and prybars. They always come in handy.
Having the above will let you fix 95% of your car.
Oh, and it's good to have a torque wrench, too.
Thanks Van, I think that covers it nicely!
[Have the triple-square, allen key sockets, torque wrench, oil filter socket already... just couldn't remember whether I'd ever actually used 16, 18mm spanners etc]
I like the Porsche PET website to find out tread and pitch sizes. Especially if you ever break or cross thread a bolt. Both of those have happened to me regularly. Only downside to the site is it can be very difficult to find exactly what part you're looking at since it's one big .pdf file
http://www.porsche.com/uk/accessorie...artscatalogue/
http://www.porsche.com/all/media/pdf...85_KATALOG.pdf
I know what you mean, you certainly need a lot of it if you want to drop a motor in from the top without removing the TT or crossmember
Needless to say, the toolkit also includes the essentials of duct tape, WD40 and a hammer... now that I think of it, when I was running an Alfa 155 V6 a few years back, the duct tape got me home on several occasion.
i just got a super nice set of titan ratchet flex wrenches for my B-day that go from 8-19mm http://www.summitracing.com/parts/TTN-17367/
i also like to have a set of wobble head extenders (harbor freght...... not broken yet) a set of crows feet and a air ratchet
I stopped using bailing wire. Got a spool of stainless steel safety wire. BTW, Anyone have comments on brand of tools with price/quality between Craftsman and, say, SnapOn or Mac? (SK was just bought out by a company called Ideal, no idea what will happen to that quality brand.)
I'm also fond of used tools. Better quality for less money.
Examples:
-1/4 and 3/8" ratchet - Snap-on
-Many sockets - Craftsman
-Specialty sockets (like spark plug or O2 sensor) - harbor freight
-Gear wrenches - Craftsman
-Combination wrenches - mix of Snap-on and Craftsman
-Punch set - harbor freight
You get the idea. Frequently, a cheap tool is better than no tool at all. And, also frequently, a good quality tool just makes the job easier.
