Need help with wheels for Porsche 944 Turbo
2nd Gear
Hello!
I just bought a 1986 944 Turbo. I don't know much about 944s yet, so I need help with wheel selection. I found some rims that I like, it's Konig Lace 18x8, with 5x112 pattern and 35 offset. I found online manufacturer who makes wheel adapters and they can make and adapter that will fit 5x130 vehicle and 5x112 wheel, the adapter is 1.25" thick. Will that set-up work with my car?
Thank you!
Thank you!
It can be done if the offset is large enough to allow for a second set of studs. I did this to mount a set of aftermarket 10x18 Porsche wheels on my BMW. That was 5x130 porsche studs to 5x120 BMW lug bolts. The spacer was 30 mm, made by radusa.
I did it because the wheels were laying around. You want 'em?
Regards,
doug
86 951 (http://www.pcaucr.org/visuals/photos...egory&catid=61)
01 E320 (W210) 4matic Wagon (http://www.benzworld.org/forums/w210...body-do-2.html)
00 540i-6 (http://forums.bimmerforums.com/forum...hp?albumid=976)
94 855 turbo Wagon (sold in 09)
85 535i-5 (sold in 07)
76 300D (sold in 92)
83 944 (sold in 86)
I apparently only buy cars designated by numbers
Regards,
doug
83 944 (sold in 86)
