help me find year of this ecu part number
if someone can send me a link to ecu info I am trying to find out what year model etc used this ecu
mainly if its a match to a 83 2.5 engine
bosch
0 261 200 086
944.618.121.05
typ 944 mws-02
bosch
0 261 200 086
944.618.121.05
typ 944 mws-02
I am trying to work out a problem I am having with the car losing power and going lean when the WOT tb switch is engaged. wideband goes 16. I am wondering if the swap the prevous owner did has the wrong mix and match in regards to engine to ecu to sensors etc.
the motor is a 83 for sure so you guys now say 88 ecu.
so I question if I have the right MAF/ DME CTS etc.
Rainman
as long as the DME/AFM are the right pairing (early/early or late/late) the car should run fine, assuming everything else is in order. an early motor does not care if it has a late dme as long as it has a late AFM as well, and vice versa.
