Crankshaft won't turn freely
Here is a picture of said pin. I have one in a spare block laying around but these things don't look like they would come out very easily..
And here is a picture of the other block I assume has a normal one (although the bores in this one are scuffed so it's not worth using)
seems a little too pushed in to me.
I brought this back up in a related thread, as I had the exact same problem: https://rennlist.com/forums/944-turb...e-block-2.html
Installing the crank, I did everything right when using the plastigage. During the final torquing I rushed, knowing I was on the clock with the gasket maker, and forgot to line up the nose bearing with the roll pin.
I first suspected something was off when a stud began to pull out (#11 in the sequence) on 2nd and final stage (37 ft/lbs). I left it and finished torquing. The crank wouldn't rotate at all.
So the bearing is out of round and the roll pin is crushed into the block. I took 2 spare nuts and bottomed them out on the stud and got the stud back in place, for now.
Need:
1. A front bearing without buying the whole set
2. A machine shop that will safely remove the pin
3. The appropriate pin replacement. N10109001 works? It looks like a solid dowel
4. To remove the problem stud and re-apply threadlocker?
Any help would be appreciated.
Need:
