How to change cooling fluids.(Gentleman's way)
Juha shows how to change cooling fluid to 968.
Some chemistry.Mobil cooling fluid & distilled water
Adapter installation
vacuum device to the adapter
Suck all the old fluids from the engine.See the lower radiator hose
Suck new fluid from a bucket
Clean and easy way to accomplish this task
A wet vac works very well also and gets the vac nice and clean. You can get the tank emptied with a small piece of hose inserted into the vacuum hose and using your hand to make a seal at the union.
Vacuuming from the upper radiator hose and likewise from the radiator gets the rest.
-Joel.
-Joel.
