can someone tell me stock fuel pressure reg size?
some say 2.5 some 3 bar and some 3.5
alot of vw guys would use porsche 944. reg to get 3.5 . is n/a 8v same as turbo cars? |
It depends, look here (https://www.paragon-products.com/Sea...x=0&Search.y=0).
NA/951 are 2.5bar, the S/S2 used 3.8bar
I thought it was 43psi 3 bar
Originally Posted by V2Rocket_aka944
(Post 8513590)
also found out turbo s is 3.5
From Porsche PET:
944 110 198 03 = Bosch # 0 280 160 227 = 2.5bar for ’86 to early ’89 Turbo 944 110 198 05 = Bosch # 0 280 160 286 = 2.5bar for ’89 – ’91 Turbo My ’89 uses the early regulator with the barbed fuel line fitting. Later regulators have a threaded pressure fitting. In general, the 3bar regulator is used with higher than stock boost. Check Clarks Garage for more specifics. |
Originally Posted by jss
(Post 8515214)
Originally Posted by 951Saga
(Post 8515594)
From Porsche PET:
what car used this?
3.5 bar fuel pressure regulator -Part # is Bosch # 0 280 160 263 -- Porsche Part #: 944 110 198 03 |
the S, S2, and 968 most likely
(Post 8516438)
what car used this?
I have a 1987 924S and happen to have a spare NOS FPR which is Bosch # 0 280 160 263. It looks like it will fit the 924S but the original part is 0 280 160 227. As I understand this thread, the original on the car is a 2.5 Bar unit and this potential replacement is a 3.5 bar unit.
Will I do any harm if I introduce this? I'd just like to make use of spares I have :) Thanks! |
"I have a 1987 924S and happen to have a spare NOS FPRAs I understand this thread, the original on the car is a 2.5 Bar unit and this potential replacement is a 3.5 bar unit.
Will I do any harm if I introduce this? I'd just like to make use of spares I have :)" If you use the 3.8 were it calls for a 2.5 you'll need to put koolaid in your radiator and fill your gas tank with a 50/50 mix of Cuervo Gold and Gumout. :)~ |
Originally Posted by Swenny
(Post 15494309)
I actually think my SPARE is the correct part. I think the 1987 924S was supposed to have the 3.5 bar unit. These three sites seem to show the Porsche part # which translates to 944.110.198.03 or 05.... http://www.einmaligparts.com/Fuel-co...05_c_9421.html https://www.rockauto.com/en/moreinfo...263316&jsn=368 http://dcautocatalog.com/illustration/index/480484416 Seeing that the FPR is now in the stratosphere price wise. I think I'll use my spare. Complain really REALLY loudly if you disagree ;) |
Originally Posted by jej3
(Post 15494693)
LOL :)
I actually think my SPARE is the correct part. I think the 1987 924S was supposed to have the 3.5 bar unit. These three sites seem to show the Porsche part # which translates to 944.110.198.03 or 05.... http://www.einmaligparts.com/Fuel-co...05_c_9421.html https://www.rockauto.com/en/moreinfo...263316&jsn=368 http://dcautocatalog.com/illustration/index/480484416 Seeing that the FPR is now in the stratosphere price wise. I think I'll use my spare. Complain really REALLY loudly if you disagree ;) 2.5 Bars = 36.2594345 Psi and the FPR is vaccum operated, would the higher rated FPR need more vaccum to operate it correctly? https://cimg2.ibsrv.net/gimg/rennlis...eedb339ee5.jpg A fellow p-car owner posted this |
