Lindsey Racing Wastegate Help
I have a dual port WG w/ MBC...quick question....should the pressure line running to the side of the wastegate hold pressure when applied? Or gradually fall off?
Don't worry, plenty of us post/surf over here, too...
I am not running a LR DP WG (wow...I hate acronyms...) but after looking at their site, the side port comes from the MBC. How are you testing it? Are you experiencing a problem with the wastegate staying closed? It will only be under pressure when you are under boost.
