951 turbo swap
951 turbo swap
ok so my 88 951 turbo was pissing oil out of the turbo so i got a hybird garret cold side with a turbonetics cold side a LR duel port wastegate 55LB injecters retuned chips i have a test pipe (2.5in w no cats) i just got my finial parts in today i needed a 3inch to 3 inch jpipe since stock is 2 1.2 to 3 inch just want to show u guys some pics
hopfully i will be making some power
lets seee the job wasint that badd it was just when i was buting the new turbo on i found i needed little stuff and yes the garret bolted bolted up but it all ready came off a 944 turbo so it was all ready adapted for the car they job was about a 6 hour job im just about done with it. the turbo and wastegate i got used for 400 bucks great deal no shaft play the injecters and retune of chips 500 jpipe was 150 so all together including gaskets and seals about 1300 give or take
ok so i finished the car yesteerday she started up fine idle is better then it was with the stock turbo and parts and the throttle is very responsive one prob i ran into is that i have the lindsway racing duel port wastegate and i hooked up one of the hoeses wrong so i was only getting 8psi of boost but im goin to fix that today
