Specs on fuel sending unit?
I cleaned my sending unit while I was replacing my fuel pump since I had the 3/4 reading when the tank was full. I forgot to test things before I cleaned it but I did test after I cleaned it. I got a reading of 2.6ohms when I turned it upside down like the tank was full. The gauge shows about 7/8 now when I tested it by turning the sending unit upside down. Does it tell you in the shop manuals what readings you should get?
http://boards.rennlist.com/upload/SenderGaugeTest.JPG http://boards.rennlist.com/upload/SenderFull.JPG http://boards.rennlist.com/upload/SenderEmpty.JPG I thought I would post a pic of what I used to remove the sending unit since when I searched there was talk of a special tool. http://boards.rennlist.com/upload/RemoveRing.JPG Thanks |
See if this is what you need:
<a href="http://www.tech-session.com/Paragon/Tech/944_fuel_sender.htm" target="_blank">http://www.tech-session.com/Paragon/Tech/944_fuel_sender.htm</a> And thanks to those who have gone before us! |
[quote]Originally posted by newoldguy:
<strong>See if this is what you need: <a href="http://www.tech-session.com/Paragon/Tech/944_fuel_sender.htm" target="_blank">http://www.tech-session.com/Paragon/Tech/944_fuel_sender.htm</a> And thanks to those who have gone before us!</strong><hr></blockquote> Thanks thats exactly what I was looking for <img src="graemlins/beerchug.gif" border="0" alt="[cheers]" /> . I guess my needle might need a little adjusting :rolleyes: |
