View Poll Results: street combo; de-stroked LS7 388 c.i. vs LS3 376 c.i.; which would you run ?
LS3 376 c.i. (Crate Engine Depot); $7,300 (see top of page 4)...
27
60.00%
LS7 block w/ ls3 crank @ 388 c.i., LS3 heads/intake LS7 cam; $9,900.
18
40.00%
Voters: 45. You may not vote on this poll
LS1 swap/parts/LSD transmissions...
Old 12-18-2017, 10:43 PM
  #301
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
Originally Posted by morghen
Love the.....
low rpm?
(redacted)
Old 12-18-2017, 11:29 PM
  #302
AnthonyGS
AnthonyGS's Avatar
So I'm mulling over an LS1 based conversion for my 944. Honestly it looks like a 10-12k investment minimum to get my 87 converted and getting a turbo or s trans. That's using a budget $2500 high mile f body ls1 as a donor. Will it be worth it? Then I will blow another 10-15k on paint, all new everything an lsd, new interior.... is it really worth it?
I can do a Miata conversion just as easy. Is it better?
Or I can buy a low mileage c5 Z06 for the same price and just drive the ever living hell out of it.
What really is better?
Im selling my 78 Vette soon to start / partially fund this madness one way or another.
1) 948?
2) v8 Miata?
3) c5 z06?
Or blow up my m96 on the track for even more $$$$$?
Old 12-19-2017, 02:16 AM
  #303
odurandina
Team Owner
odurandina's Avatar
Originally Posted by AnthonyGS
So I'm mulling.......
$20, 30k up to $120-200k .... The only limit is your imagination. You stop on a particular item/ system when you're satisfied. ...i've driven my 968 39,800 miles in the past 2 years since the swap, six transcon trips of 3,200 miles.... 1,200 miles in the past couple of weeks....and 140 miles today. It's been off the road too -- and lots of stuff continues to be done. Some guys focus on suspension and brakes. But there's really no end to it. I'm daily driving a very sorted car that cost an obscene amount. Couldn't have made it without "the Bray, and his insane wrenching skills." The interior upgrades are the latest scandel. Got some help from Lart with an extra cluster to mess with for a trial run. It's weird driving it lately. It's like i checked the boxes on a list from a menu at Alice's (Porsche) Restaurant.
Old 12-19-2017, 03:30 AM
  #304
morghen
morghen's Avatar
Yea that gearing is extremely high. Quite pleasant for highway cruising...I understand, I also like a car that can scream when pushed and be quiet when just traveling.
Look, I wont argue that the guy does good work for few money compared to OEMs but on such small parts its extremely difficult to get good quality and the stuff on your car is in my opinion not, who cares about a few grams of weight shedding when you've got a V8 ffs...where is your logic man?
Anyway, have a look at your pictures in parallel to these:
You just CANT beat the factory design of Porsche...this is the absolute best looking front end for the 968.
Old 12-19-2017, 08:43 AM
  #305
ealoken
ealoken's Avatar
That wing :O
Old 07-09-2020, 11:53 PM
  #306
odurandina
Team Owner
odurandina's Avatar
Morghen,
The Audi carbon looks great. But that would look very awkward and out of place for a mid-90's 968. To anyone including Porsche folks, my interior looks quite normal mid/late 90's Porsche wedged between the 993 & 996, as i desired it to be.
https://rennlist.com/forums/968-foru...-968-a-54.html
A great thread that should be moved to this forum.....
https://rennlist.com/forums/944-and-...eproduced.html
from a few days ago
Originally Posted by brooklyn944
This is tangentially related, since it's not NLA, but I think I could speak for many by suggesting that an updated version of the armrest cover hinge piece that doesn't break so easily would be great. Especially because replacements still run at ~$60
Carve a block of balsa or basswood.
Cover it w/ leather or carbon fiber.
You'll have fun making it.
Old 08-18-2020, 06:37 PM
  #307
odurandina
Team Owner
odurandina's Avatar
FOUND: 968 Hood latch cable at Suncoast Porsche in Sarasota.
https://www.suncoastparts.com/product/94451103702.html
Life is good
Old 08-30-2020, 09:11 PM
  #308
odurandina
Team Owner
odurandina's Avatar
Originally Posted by s85b50
Aren't the basic ones solid while ultra mounts are solid with rubber inserts on them? I wouldn't exactly call them semi-solid in structure but vibration wise.
Originally Posted by MAGK944
Yep, again though I thought this thread was about the Ultra Mounts not the solid ones.
I had the Ultra Mounts and would never recommend them for a street car. I suppose you could describe them as semi-solid as they were not solid aluminum and had rubber isolators instead of fluid like the factory mounts.
i'm in a bit of an odd situation with my LS to Porsche crossmember mounts mounts. i'm not keen to get into the deep weeds to swap out the worn out, no make that DEAD Gen I *TPC mount bushings (i forget who made the rubber inserts). The urethane bushings (Gen II), are sold by someone, but after all this time i've forgotten by whom. Been running these (now) not soft mounts for a long while---and the V8 is pretty smooth. At 53k miles, It makes me question the necessity for however much dampening is accorded w/ fresh rubber.
Adding a mount replacement interval just adds another thing. Are the mounts important to lessen abuse to the suspension, serpentine, accessories, hoses? Might be the only item i'd look to source from TPC, as everything else off the kit, all the other stuff Eric Hill put on has held up well. i still think like there's enough to worry about already keeping up with the remaining normal wear items on the car.
Maybe i'll install new bushings when the control arms need to come off. That might be a while yet.
*TPC = Texas Performance Concepts (not run by Eric Hill since 2015)
Quick Reply: LS1 swap/parts/LSD transmissions...
