radiator hose continually blows off water pump?
8th Gear
This thing has become a nemesis. No matter how tight I tighten the clamp at some point on a hot day the hose has come off the water pump and leaks coolant.
I have replaced the clamp with a regular stainless steel screw type clamp, but still happens. I have also replaced water pumps and thermostats with same result.
How tight should I tighten this clamp? Or is some other possible cause?
Alan
Alan
What year and model? N/A, Turbo, S2?
Is it running hot? Which hose? Is there oil in the coolant? You say that you have replaced water pump(s) and thermostat(s). On this car? You should not have to tighten a clamp so tight that it squeezes through the slots on clamp. You may have a lot of air in the system.
I had a similar problem with my 88 944 n/a, but it only happened once. The radiator hose blew, and I got a new one and fixed roadside. The new hose came off a couple of weeks later at the top. The hose clamp was loose, so I put it back on, this time in the garage. When the hose looked straight from the top, it was cocked at the bottom. I put it in from the bottom with a friend on top making sure it was on straight and the problem has not come back.
Good luck.
Good luck.
