LS3 C6 Corvette vs 951 Bolt on
Old 07-04-2010, 12:51 AM
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
Originally Posted by V2Rocket_aka944
a 951 running 4 psi higher than normal...
Yeah - which takes something bigger then a K26 up here...
Old 07-04-2010, 03:40 AM
V2Rocket
Rainman
V2Rocket's Avatar
thats where the K27 comes into play, unless you're sid and need a peterbilt-style HX45 or whatever that thing was
Old 07-04-2010, 03:48 AM
Rogue_Ant
Rogue_Ant's Avatar
Lol yeah - one turbo he played with was IIRC 72mm inducer! A 900hp capable turbo... He said it hit 15psi around redline, lol.
I've got an HY35 waiting for me to find some time... Not a direct bolt-on, so need to actually have a free weekend to build a new DP and modify the cross-over.
Old 07-04-2010, 09:08 PM
GGe
GGe's Avatar
But guys... What do you fell about 944 with an LS V8 motor? Wrong...?
Have the good looking , awesome handling Porsche with a cheap , powerful aluminium V8...
I think its wrong... But it is the cheapes way to getting 944 real power.
Old 07-04-2010, 09:33 PM
piperporsche180944
piperporsche180944's Avatar
I think its perfectly fine as long as they re badge is as a 948 and if they are able to beat a 350rwhp 951
Old 07-05-2010, 12:00 AM
V2Rocket
Rainman
V2Rocket's Avatar
well, **** hahaha
Old 07-05-2010, 01:40 AM
Rogue_Ant
Rogue_Ant's Avatar
Depends on your end-goal. If your goal is 350rwhp, then no swap is going to compete, economically, with the 2.5 turbo.
-Rogue
Old 07-05-2010, 07:12 PM
GGe
GGe's Avatar
Going for twin turbo LS1 ...
Old 07-05-2010, 07:21 PM
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
it's king kong with a "Fast" 102 mm intake, about 8.5 thousand dollars and 445 hp...
properly taken care of w/ plenty of fresh Mobile 1, the engine is likely to outlive the driver.
and you can show at the Texas Mile....
with the other you can work on it a lot, but it's still a lot of fun to drive.
at some point, and i'd hazzard guessing maybe some point after 80 k miles, you break even on $$$.
i'll take tons of **** for saying that, but that's just my 0.02.
Old 07-05-2010, 07:28 PM
Rogue_Ant
Rogue_Ant's Avatar
Lol - then you better consider what the rest of the drivetrain can handle...
The 944 is not a good platform for 1000+rwhp.
Old 07-05-2010, 08:07 PM
V2Rocket
Rainman
V2Rocket's Avatar
unless you get a custom gearset made...torque tube should be fine with a good rebuild, the 928 guys are putting like 700hp in some cases through theirs and they have the same bearings we do...maybe some 930 axles or custom?
although regardless imo thats still kind of a pointless number to try to achieve...
Old 07-07-2010, 05:40 AM
odurandina
Team Owner
odurandina's Avatar
theres more engineering in that LS3 than probably a whole 944
thank you. the bright spots in the american automotive industry are few. this is one.
ummm....
the weak link is the input shaft. and when it breaks, well...
Old 07-07-2010, 05:47 AM
Rogue_Ant
Rogue_Ant's Avatar
It is a good engine - but I think you underestimate the amount of engineering that goes in an entire vehicle...
Old 07-07-2010, 03:21 PM
Cole
Cole's Avatar
The engineering that went into the 944 is very impressive concidering that it can hang with modern sports cars on so many different levels.
Old 07-07-2010, 03:30 PM
V2Rocket
Rainman
V2Rocket's Avatar
input shaft to the transmission?
Quick Reply: LS3 C6 Corvette vs 951 Bolt on
