1986 944 n/a brake upgrades
#46
Thanks Nashio, I think I'm going to tap it and use some tape.
On a side note, I've finally ordered everything I need for the swap, but I was wondering if it is possible to use the NA caliper bolts for the turbo caliper bolts on to the turbo spindle.
#47
I'm looking for a good used 928GTS rotor to do another mock-up using Wilwood SL4R's. I'v already done the mock-up long ago using the LS430 caliper and Cayenne rotors.. The only way I would even consider putting 322mm or 330mm rotors on an early car is installing billet hubs. A few of you (early cars)have gotten them but haven't posted install pics with larger rotors.
Reason for doing SL4r mock-up is that the radial mounting is 152mm and can fit 94mm turbo spindles too, whereas the LS430 130mm radial mounting can only adapt to the NA 76mm spindles.
