Delrin bushings for the spring plate
I've been thinking about putting delrin bushings in the rear swing plate on my '83. Everybody talks about the positives, but what about the negatives?
Will the ride be harsher? Will the car be noisier inside? Will they squeak? Will they last long?
I did it. No noise no harshness. It did require a little bit of sanding in order to fit inside the torsion tube. Once you remove the rubber bushing, and completely clean both surfaces, the delrin will slip over the spring plate, but it may not fit inside the torsion tube cleanly. I had to sand them down. You want snug, but not so snug that the spring plate cannot rotate freely (with some friction).
getting the rubber off is super easy for me now heh. takes literallly 5 minutes.
get a MAPP gas torch from home depot. fire it up and heat the inside of the spring tube till the rubber starts to smoke, takes about a minute continuous. run a xacto blade along the circumference of the bushing where it touches the flat spring plate. drive long big flat screwdriver down length of the rubber bushing, pry up and out. bushing will either come off as a donut or split in two. any residual, just use the torch and burn it till it's warm and squishy and wire brush it off. finish with soft wire wheel on drill. sparkling clean
It's all in the prep work. Use a brake hone to smooth out the recesses that the bushings set into. That way you're putting a perfectly round bushing into a perfectly round hole, less chance of binding. The bushings might need to be pressed onto the spring plates, no big deal any repair shop can do it if you don't have a press (make sure they put them on the right way!) As Greg said they should be real snug, barely able to move them by hand. Any play and you're defeating the purpose. I've had mine in for 5-6 years of track duty now, no binding or squeaking.
In this pic the end cap on the right is honed, the one on the left is not:
Herr Unmöglich
The job took me forever to clean all the spring plate bushings up. What a PITA. I run the Welmeisters at this point and those are the least of my concern when it comes to harshness and vibration in the race car!
