Rear defogger help needed...
Recently purchased a 968... When I received the car, among other things, the rear defogger didn't work. After looking at a bunch of old threads about issues with the rear defogger circuit, I began troubleshooting the circuit. I found that when the switch is turned on I get about 12 volts on the driver's side of the circuit and 0 volts on the passenger side. I have continuity throughout the circuit and about 275 ohms across the defogger itself with the connectors on the lifts disconnected... Still no heat in the defogger when hooked back up... I am very frustrated!!!! Any ideas...
Thanks for your response!
-CKKrause
-CKKrause
Clark's site says, ...if I read it right.., there shouldn't be any voltage on the passenger side.
With respect to the connectors, I get continuity from the base of the drivers side support strut connector to the passengers side strut shaft...
-CKKrause
Check your struts... I bet you have no continuity in one or both struts... my 951 PS strut makes "intermittent" contact... a wire brush can make a world of difference...
I made 2 jumpers so that I could take out the struts out of the circuit completely and I still get nothing on the heating grid...except approx 12 volts on the driver's side...
Still frustrated!!!
-CKKrause
