Part Number for electrical connector
1 Attachment(s)
x post
THe plug on my Hall Sender wire (944S2) crumbled from heat and age but the sender is still working perfectly. Does anyone know if you can buy the MALE part of the connecter (i.e the part of the connector that is on the end of the Hall Sender wire). The part number for the FEMALE part (i.e the part on the wiring loom) is 022 906 233 B - pic below Also after the part number for the metal clip that holds the connector to the metal plate behind the distributor. Can't see it in the parts diagrams but I'm sure I heard mine fall off when the connector crumbled?:mad: Thanks |
THis should get you started in the right direction.
https://rennlist.com/forums/7218603-post19.html |
Was the question ever answered? Is the male-end connector available?
Thanks to Roger of 928sRus in the DFW area, who carries kits for both the female- and male-end connectors with pins and boots, for $18.50 per kit. He's also pretty handy at fixin' stuff, helped me repair the solenoid wire on my starter and get on my way (driving from Austin to Denver).
