Ignition Coil Connections
After a failed attempt to install a standalone EMS system, I am installing all the stock stuff again. I just didn't have the time to put into it.
Anyway, what color wire on the Stock ignition coil goes to the larger (or smaller) stud on the coil? I cut the eyelets off, so I need to put the correct size eyelet back on each respective wire.
thanks,
Adrial
thanks,
Adrial
