alllllmost done.... build pics
Old 02-15-2010, 09:34 PM
  #181
Cass944
Cass944's Avatar
i know right... wtf
i guess i was pretty hard on them when i was pulling the wiring harness back behind the engine...
Old 02-15-2010, 11:18 PM
  #182
Cass944
Cass944's Avatar
i thought i had a timing light around here somewhere to test for spark... now i cant find it
bump for an answer on my multimeter question...
Old 02-16-2010, 12:26 AM
  #183
n_hall
n_hall's Avatar
i have an extra sensor you can have. i replaced it when i had a no-start but it ended up being that allen set screw you were talking about before. i dropped a bolt in the inspection hole and it sheared that off. that was an expensive mistake. i guess you can drive down or if yuliang wants to we can take a trip up? or you can give me your address and i can ship it up to you. i don't want anything for it, just a gift from one 944 owner to another. let me know how you want to do this, that is if you even want the sensor.
Old 02-16-2010, 12:41 AM
  #184
Cass944
Cass944's Avatar
wow, sure yeah i was actually just about to ask if anyone had a known working sensor i could try. as far as i can tell (unless im using my multimeter wrong) i need 2 of them. but hey I'll take anything i can to get this thing going sooner
my birthday is this friday. me and my ladyfriend were planning on coming down to go to penny's and get some spicy noodles. i wouldnt mind driving a bit further to come pick it up.
Old 02-16-2010, 01:49 AM
  #185
951Saga
951Saga's Avatar
Hey Brett, I have an old one that came out during a “while you’re in there” exercise, car ran well with it in, but found it had impact damage from being set too low. Even damaged it measured 1.016K ohms when tested like your first pic and open at the outer two pins like your second pic. Pity there is damage or I’d send it to you.
Old 02-16-2010, 04:14 AM
  #186
n_hall
n_hall's Avatar
i've never heard of penny's. where is it? i wouldn't mind driving a bit this weekend.
Old 02-16-2010, 09:47 AM
  #187
krystar
krystar's Avatar
heh u wanna deliver a pair of exhaust manifolds to brett too?
Old 02-16-2010, 10:33 AM
  #188
Cass944
Cass944's Avatar
penny's has a few locations. there one on willow road right off of 94. theres one near diversey and clark downtown. and one near wrigley field. theres one kind of closer to you on ummm chicago ave and harlem ave in oak park.
and hah yeah i never did get down there to pick up that manifold... i just went ahead and stuck my original one on for now. it has a small fracture in it but i figure it will be fine until i get something better. I kinda want to just get one of those msds/bursch type of setups. but ive been hearing nothing but bad reviews
Old 02-16-2010, 11:15 AM
  #189
krystar
krystar's Avatar
wrigleyville...all i do is hit up rock bottom hehe
Old 02-16-2010, 01:28 PM
  #190
Cass944
Cass944's Avatar
dammit... witch hunter is closed until the 26th
Old 02-16-2010, 08:06 PM
  #191
Cass944
Cass944's Avatar
before i invest in new sensors... can i get a confirmation on weather or not i tested mine correctly?
the pictures are on the previous page
Old 02-17-2010, 03:17 AM
  #192
n_hall
n_hall's Avatar
everything looks good, settings too. try testing your meter. put it on the lowest ohm and touch the 2 leads, you should get 0 or somewhere a little above depending on how accurate your meter is. but not above 1. i had 2 meters give bad readings when the batteries were going, might want to try changing them. can also try testing it with a wire too, just a few inches long and you should get a higher reading.
Old 02-17-2010, 01:02 PM
  #193
Cass944
Cass944's Avatar
hmmm damn.. yeah if i touch the contacts together the meter goes to zero. but apart it says "1". and when i touch the leads to the contacts in the plug it stays at "1"
i was just surprised i got absolutely nothing from either sensor...
Old 02-18-2010, 08:57 PM
  #194
Cass944
Cass944's Avatar
well i talked to damian and convinced him to let me steal the sensors off his car to try on mine...
so i guess ill be giving that a try on sunday
Old 02-25-2010, 10:02 PM
  #195
Cass944
Cass944's Avatar
alright so i ordered new ref/speed sensors from paragon... I hooked my multimeter up to them to measure the resistance across the contacts and i still get nothing. So i must just be doing this wrong and mine were probly fine the whole time.
Quick Reply: alllllmost done.... build pics
