Risks with opening up cylinder head chamber volume?
Shoot, I personally know 2 people that threw MP62's on their high compression motors. One 10:1 and that other 11:1. Both were putting out about 300whp. One non-intercooled. Both run GREAT!!! I'm talkin quick. One, a V6 Tiburon, is getting built up with a larger turbo (GT35 IIRC) and ran 13.2's on slicks. The other, a K24 Integra, is still running without an intercooler and as of yesterday, laid down 302 at the wheels. He pulls 13.1's-.2's on street tires.
FWIW, if you really intend to do this yourself (a very steep learing curve I imagine), the suggestion of starting with a scrap head or two is a good one. At least you'll get some idea how thick the casting is. It might be a good idea to slice it into sections on a heavy duty band saw to see what the wall thickness measures out to around the combustion chamber wall/cooling passages. I don't know how you can shade-tree the effect on chamber squish/gas flow characteristics. Racing engine builders guard these kinds of sectrets on which they've spent big dyno and flow bench dollars learning.
Rainman
Rainman
