S3 engine behavior questions
Okay, finally the S3 is outta garage and at home
But we have some issues when the engine is warm
1)it refuses to start
2)engine stalls if car does not move & gear is engaged
2)idle dwells a little (sometimes)
3)exhaust smells a bit rich
When the car has just started it performs flawlessly (And is absolutely GREAT to drive!!!!)
So, what could it be ? TPS stuck? ICV (idle control valve) broken?
And continuing, TPS is changed and ICV cleaned ; and it seems to work ok. Could this be a vacuum leak somewhere? Car idles at 1500 when it starts up but as she warms idle drops to 1000-900 and hovers there...
As for idle, 950 sounds fine after warm up. Vacuum leaks typically cause the engine to surge a low rpms.
Lemming , no it's not clear. The idle dwells when she warms up so there must be a vacuum leak somewhere. The thing is that I did do anything for the engine apart from belts, rollers and new waterpump + checked the condition of the slider pads under the valve cover.. So there can be almost anything broken :/ Because of the situation I guess I have to open the whole intake system and change old hoses etc...
Whe she has been just started she idles at 1500 and revvs nicely and gives absolutely great performance)...
