OFFICIAL 944 S3 Registry Thread
With all the folks putting 968 engines in 944's, etc...let's start a registry. Please provide the following:
1. Base Car info (year, model, etc)
2. Car info (interior / exterior color, etc)
3. Options on original car?
4. What year 968 engine
5. Mods
6. A brief explanation of why and how long it took, challenges you faced, etc.
Let's keep track of the folks out there doing this. It may be of a great help to those who are interested in doing the same swap.
Thanks!
C.
5. Mods
Thanks!
C.
I'll start. Here's my car info:
1. Base car - 1989 944 S2
2. Color- Alpine White on blue (now black)
3. Original chassis miles: 147K
3. Options - Limited Slip trans, non-M030 (everything else removed)
4. Engine info - 1995 968 motor with approx 60K miles
5. Mods:
Engine:
- Custom oil pan baffle
- modified DME chip
- Custom intake
- Crank scraper
- Reinforced oil pick-up tube
Exhaust:
- RSBarn / Racer's Edge long tube headers
- Racing CAT
- Full Custom stainless J3 3" exhaust
Drivetrain:
- S2 flywheel
- S2 Clutch / damper
- replaced clutch slave / master, & lines
- Aluminum shift block
- New half shafts / CV's
- Solid Trans mount
- Replaced Torque tube with 60K mile unit
Suspension:
- Ground Control fully adjustable coilovers (front & rear)
- Torsion bar delete
- All bushing replaced with delrin & poly bushings
- GC front camber plates
- 500lb front springs / 600lb rear springs
- 968 M030 adjustable sway bars (front & rear)
- Front sway bar reinforcement plates
- New front control arms
- New Tie Rods
Interior / Safety:
- Fully gutted interior
- 4 pt custom roll bar (goes to a full cage next year)
- Fire extinguisher
- Momo suede racing wheel
- Rennline floor plates
- Evo 2L Seats (x2)
- G-Force 5pt harnesses
- Custom CF door panels
- Custom CF center console
- Aluminum SRP Racing pedals
Exterior:
- Front CF GT Racing fenders
- Custom painted 996/boxster twist wheels
- Hard mounted sunroof panel
- Rear wiper delete
- CPR front V1 splitter
- Custom CF fog delete panels
The Story:
For years I have wanted to build my own toy. After selling my last 996, I decided to just do it. Found a high mileage donor and began work in July of 2008. This has been a labor of love, with a twist of throwing tools and swearing. It has not been easy. But seems to be completely worth it. The goal for the car was originally to be a 944 S2 Spec car. But after finding a cheap 968 motor, and my wife becoming pregnant with our second child, the car is now a dedicated weekend track toy. My intention is to get certified as an instructor and teach fellow enthusiasts to enjoy their Porsches.
cheers,
Chad
The "preview shot" until the car is fuly completed:
5. Mods:
Engine:
- modified DME chip
- Custom intake
- Crank scraper
Exhaust:
- Racing CAT
Drivetrain:
- S2 flywheel
- Solid Trans mount
Suspension:
- New Tie Rods
Interior / Safety:
- Fire extinguisher
- Evo 2L Seats (x2)
Exterior:
- Rear wiper delete
The Story:
cheers,
Chad
1. Base car - 1983 944
2. Indishrot (India/Guards Red)
3. Aprox 160K
4. Manual steering, Manual Sunroof, Rear wiper delete, Basically barebones 944.
5. 1995 968 motor with 75K miles, 5k since rebuild
6. Mods:
Engine:
Custom intake
Lindsey Ultra Mounts
Fresh bottom up rebuild 5K ago
Drivetrain:
S2 Flywheel
S2 clutch/damper
1989 944 S transaxle
Brakes
Rennbay Big brake kit
Everything else (exhaust, suspension, etc, interor) is stock minus speaker/wiring upgrade and a new deck, and some tequipment floor mats... Still running the stock cookie cutters until I source me some spacers to run my 16" c2s.
The story
One sunny day cruising along lakeshore, give the car a blip and remark at how responsive and great the 2.5L slug felt. 3 minutes later my rubber centre disintergrates and leaves me stranded. The next year was spent sourcing parts and getting everything ready for the transplant.
Problems? Making the late engine wiring harness work in an Early car, figuring out the routing (since the late harness should route to the passenger side, and the early harness runs through the driver)
Other than that and the fact that I had to remove both shims on the Lindsey mounts for the intake to clear, everything was smooth as silk.
3. Aprox 160K
6. Mods:
Engine:
Custom intake
Drivetrain:
S2 Flywheel
S2 clutch/damper
Brakes
The story
hi, here's the #1 S3 in Finland
1. Base Car info : Stock '91 S2
2. Car info : Traditional Red / black interior
3. Options on original car: M474
4. What year 968 engine: '92 80tkm
5. Mods : engine ; none. Car: 951S shocks and struts, 951S brakes, TechArt exhaust
6. Story : The S2 engine broke aparts for reasons yet unknown. The project scheduled for 2months but it tooks more than 6m as there were lots of changes in my non-Porsche life . The tricks to get this working were:
- S2 flywheel
- S2 referensce sensor stand
- 968 reference sensor
- Short circuiting ignitor control module
- Pin #7 (in passanger footwell) connected to +12V
- S2 flywheel
1 Post
1. Base info: 90' s2
2. Donor: 93' 960 70,000 miles
3. Mods: Straight pipe to Magnaflow, custom intake
4. Install time: Two days (25 hrs)
5. Story: Engine had about 240,000 on it, and I wanted more power
I have an '85.5 944 that is a track car for DE's and TT's.
I have a lead to buy a low mileage 968 engine.
I am looking for pre-build advice from anyone who can help.
I can get the engine with the torque tube, but not the transaxle. My transaxle already has a Guard Transmission LSD in it. The current car setup is to PCA and NASA 944spec class, full cage, race seats, 6 pt. harness, etc. The engine swap would change classes, but I am ready for more power and don't want to install a complete turbo setup.
So, will the 968 torque tube hook to my transaxle? or do I need to try to find an S2 bellhousing to mate my my current torque tube to the 968 engine?
What about electronics and wiring harnesses?
Greg
Greg
I did the swap in my 86 and used the 968 torque tube to mate up to a 944S tranny w/LSD, so that does work. I made a thin metal gasket to go between the torque tube housing and tranny to keep dirt and water out. I put in a 951 radiator which required the lower radiator support from a 951 and a plug to block off an unused outlet.
As for wiring, you use the 968 harness and computer with a few wiring mods that you can find if you search the list, mainly a 12V continuous source to a couple pins and running the tach output to the 4 pin connector in your existing harness. I installed a late model dash cluster with the engine warning light and wired that in too.
1. 1988 924s (cream puff with 38,000 miles)
2. Guards red/black interior
3. Not many
4. '95, '94, '95 and yes I'm on my third engine
5. Too many to list.
6. Original build took a bit over a month, it's been an ongoing project since then. Currently on the rack to get solid bushings throughout.
Photo taken at the UTCC at VIR a month or so ago.
3. Not many
2. Color- Red on Linin
3. Original chassis miles: 109K
4. Engine info - 1993 968 motor with approx 60K miles
Engine:
-Stock
Exhaust:
Stock S2
Drivetrain:
- S2 flywheel
Suspension:
- Koni's
Interior / Safety:
Stock but the next for work
Exterior:
- Euro driving lights with fog lights
I took the easy way out and let the shop do the install. This car is the first that I let anyone do my work, work took up to much of my time. Had heavy scoring on the cylinders and the cost was about the same and the added power was needed. I will be looking at some more power this winter.
Engine:
-Stock
Exhaust:
Stock S2
Drivetrain:
- S2 flywheel
Suspension:
- Koni's
Interior / Safety:
Exterior:
1. Base car
1989 944 S2
Color- Yellow
Original chassis miles: unkonown
Options - M030 brakes, LSD 5 speed transaxle
Engine info - nikasil plated block, arias pistons, carrillo rods
Engine:
- RSbarn DME chip
- Custom intake
- Crank scraper, lindsey baffle
- Setrab oil cooler
- Accusump
Exhaust:
- Full Custom 2.5" exhaust
Drivetrain:
- S2 flywheel
- only944 short shifter
Suspension:
- Leda double adjustable
- Charlie arms
- Heim joints every where.
- 968 sway bars
Interior / Safety:
- Full cage
- Sabelt fire system
- AIM Mychron dash
Exterior:
- Fiberglass fenders, hood and roof
- Lexan quarters and hatch
- Kinesis K27, Clubsports, and Tr motorspors wheels
- APR GtC300 rear wing
- Race weight is 2615 with me in it and no ballast.
The Story:
Looking for an S2 or S3 race car led me to buy this one from Seattle. I had to rebuild the engine due to some cylinder scoring, but it's all up and running now. It is a really easy to drive car and was able to set some pretty respectable times in the time trial series I ran in 2013.
1989 944 S2
Color- Yellow
Engine:
- RSbarn DME chip
- Custom intake
- Setrab oil cooler
- Accusump
Exhaust:
Drivetrain:
- S2 flywheel
Suspension:
- Charlie arms
- 968 sway bars
Interior / Safety:
- Full cage
- AIM Mychron dash
Exterior:
The Story:
I know this thread hasn't seen much action in a few years but in my stable I've been busy working on.........
1. Base Car info (year, model, etc) 87 944 turbo all original 137xxx
2. Car info (interior / exterior color, etc) black on black/greige
3. Options on original car? All options except heated seats and factory rear wiper (added switch and motor from donor car)
4. What year 968 engine when this rebuilt 2.5 I just spent all summer rebuilding goes then I'm shooting for a decked out 3.+liter to fill the engine bay! At that point maybe even a bigger turbo!
5. Mods rebuilding The car soup to nuts, vdo gauges, 968 rear bumper, Lindsay racing silicone hoses, custom "test"pipe
6. A brief explanation of why and how long it took, challenges you faced, etc. so far been working on this car for a year, have always loved the 944, this 87 turbo is my second one, but I've never really cared for the back of the car, too 70's VW-Volvo looking for my taste, but the 968, have always loved the look of that rear!
james
james
