Swapping early dme to late..
I want to swap the late dme/afm into my 84. I have done some searching, and everything I have found says that all you need for the swap is the late dme, and late afm. I just want to confirm that this is ALL I need. Plugs are the same? No wiring modifications?
Yep ive done it before. The plugs are the same. Just plugs right in.
some say you need to swap idle valves but others dont.
so what's the idea here? why do that?
early DME has a stumble that happens when you let off the throttle because the fuel cutoff is set at a very low RPM so it drops to like 800 before settling back to idle.
late DME doesnt have that, also can be chipped. late DME/AFM combo has a 5v input signal so it can be used in maf conversions |
Originally Posted by V2Rocket_aka944
(Post 6562229)
take the entire DME and an entire AFM from a late car and swap them for the DME/AFM in your early car.
lol. plug and play. |
Lol yep thats as simple as it gets. Unplug late afm and dme and plug into early car. Only 2 things you need and NOTHING else.
so no need to change idle valve?
are the chips worth the trouble or is it all speculation?
WOW!!! exactly what I needed. Just asked the same question in the thread" price of late DME n AFM" I was going to buy early DME and AFM, but the guy said that he has both early and late, but he prefered me to buy the late. Said they were interchangeable ONLY if you change them both, cant do one and not the other. Didnt think of this changing the "early idle stumble", mine goes down to about 600 after I rev it alittle, then idles at 950. I didnt even think of the chipping mod that you can do also! Sweet guys thanks.
be careful with the chips as they work by advancing the spark alot. you will need to use premium gas with a chip.
I thought that the injectors also had to be changed to late model injectors when changing the DME?
(Post 6564718)
Originally Posted by John Milne
(Post 6564989)
Originally Posted by roman944
(Post 6564996)
so should the spark plugs be changed to something else/better too?
