Another 944 Project
#106
My web is rsr-sport.com
It's in Español! a English & Swedish version come soon.
I dont have all 951 parts ready.
The carbone fiber parts are done for racing, For road use the wight a little bit more.
I will come back with more info in the under the title 900kg 951
Jan K
Jan K
#108
Henk
#111
Progress
We're doing the last bits of suspension work, big black brakes are in, KW rear Competitions with 140N/800lbs, Kw fronts with 110N/600LBS, A-arms, camberplates, Weltmeister sways.
Still having some gremlins with wiring, so today decided to go MOTEC and sort it all proper.... Car is scheduled for first drive on 28 June... fingers crossed, attached some pics of underworks.
#114
Great stuff Henk. Looking forward to more updates and your impressions of the suspension. I wonder what bump & rebound settings you might end up with?
Keep up the great work
#115
Buenas Tardes
No I'm from Sweeden
If you havent seen it already I recomiend a German site called http://www.944racing.de/ it`s full of nice facts.
But to tell the truth I think you allredy has the knowledge to make a real pit
Saludos
Jan K
No I'm from Sweeden
Saludos
Jan K
#116
Jan, I couldn't see any 944 pieces on your website? Link?
#117
I decided to go for a square setup so that's 285s all round. They are Falken slicks and are not only wider than a road going 285, but also a lot taller. Hence I had to make room up front to fit them. As you can see here, they tuck into the body pretty tightly. The square setup has been proven to work well on our cars. Some guys are running up to 315s all round! You want to minimise the amount of front to rear stagger in your tyre widths. Our cars are setup to naturally understeer so more rubber up front should offset that. Dial out the rest. Ideally I would like to go to a wider rear actually but they don't make the Enkeis in a wider wheel. I will endure this setup for a little while. I have a high hp 3L motor in the wings so we will wait until that goes in to make the call.
Henk.....very nice car. where did you get the hood vents?
#118
is your wing mounted directly to the trunklid glass? or is there a support underneath? surprisingly, my wing pushed through the sheetmetal on my BMW frame rails. I could only imagine what it might do to glass.
The vents on Henk's hood are from here:
http://www.deutschnine.com/porsche-t...ning-parts.php
#119
#120
okay, just a few updates. we're waiting for the motec (2nd hand) and some wiring stuff. Then we'll have to wait for the Motec Guru in Thailand to be done with building 3 race cars for the supercar races... But we don't get bored. Suspension work goes on, fuel lines are being laid, the dash is being testfitted and will be covered with alcantara and yellow stitching. So here's few more pics.
Henk
Henk
