2 part suspension question
Ok, I installed my rear coilovers tonite, but after reading mike's thread i am VERY nervous, and want to make sure that i Torque everything properly. I torqued the main lower bolt to 85 ft. lbs and it didnt seat tight against the control arm, so i went to the manufacturer spec of 150 that was thrown around in the other thread and felt much better about that, but i could not find any reference to a torque for the bolt that actually holds the coilover on??? I judged by feel that 50 ft. lbs was suffiecent, and didnt want to go crazy till i knew for fact the proper torque.
Second question. I have heard in the past that using delrin on the sway bars is fine but you need to leave part of it rubber so nothing binds, is using 1 rubber riser and 1 delrin adequate, or do i need to also make the endlink rubber if the center is delrin?
Thanks, Mark
Thanks, Mark
Mark, the Racer's Edge lower shock mounts/bolts come with bolts that have a cross-hole drilled in the head. This is for safety wire - a good idea.
From the other threads - especially with the Ground Control mounts, make sure the shoulders are FULLY seated against the control arm. A good way to test is to see if you can slide a piece of cigarette pack cellophane BETWEEN the shoulder and the control arm. This cellophane is 0.0005" (half of one one-thousandth).
To answer your 2nd question... you want to use delrin mounts for the stock sway bars? What about the drop links?
Per workshop manuals:
Shock absorber to Body (top mount) 45 ft/lbs
Shock absorber to Steel trailing arm 45 ft/lbs
Shock absorber to Aluminum trailing arm 91 ft/lbs
Per Racers Edge: (thanks Van)
Racers Edge Lower Shock Mount Bolt 150 ft/lbs
For the front sway bars i plan on using the delrin for the sway bars, the two center points, and one of the droplink bushings, the other droplink being rubber and the outers being rubber. My question is do i need to use that much rubber, or can i use 2 delrin pieces for the drop links and just leave the end bushing rubber. For the rear i am using the delrin kit from Paragon that uses aluminum blocks instead of the factory straps, and Paragons adjustable drop links.
Any suggestions appreciated...
Mark
I have the Tarret adjustable sway bars - and those use delrin bushings and ball-joint drop links (heim joints). Obviously, those are all solid joints - there is no flexing going on - and it works fine.
Are you thinking about a set of Rennbay's sway bar mount stiffeners? I would use those.
My hunch is, you're better off with rubber where the drop link connects to the bar, but delrin where the drop link connects to the control arm.
Because the bar will pivot (like when you jack up the car) the angle with the drop link will change dramatically and might cause the delrin to break. Ideally you should put on an after market front sway bar that is designed for solid mounting.
Just my 2 cents.
Just my 2 cents.
Mark
Just my 2 cents.
Just my 2 cents.
Thats what i was thinking, but at least Paragon doenst offer the outer delrin bushings for anything but the 30mm bar. For now i am going to run my 26.8 mm bar till i have them money to get the 968 M030 bars.
Mark
Oh man, preaching to the choir I am...I'm surprised RE does not give this value with their bolts. I have not ordered my coilovers yet so can't help, but also curious. Don't forget to post up some pics once complete.
Mark
