Changing Headlight Bulbs.
Super easy!
Turn headlights on so they pop up. Remove relay for motor assy. Turn headlights off. They should stay up BTW w/the relay pulled.
Remove the one screw holding the black plastic shroud on around the lens. Then remove the 3 tiny screws (use a magnetized screwdriver if you have one. DONT DROP THE SCREWS!) The trim ring will come off, and the light will slide out. Undo the electrical connector and you are done!
In true instruction style.... re-installation is oppisite of dissasembly.
