Fuel pressure question
Now that I have a fuel pressure gauge on my fuel rail I can see that the fuel pressure slowly bleeds off after the engine is shut down. I thought that the fuel rail was supposed to remain pressurised
Is this normal ?
(AFPR is new, so perhaps my damper is bad)
Is this normal ?
Normal
It will loose pressure in IIRC 30 minutes or so.
The manual gives a minimum time on this.
If yours is faster that the check valve in the return line may need some cleaning.
If fuel pressure is no problem while driving, I would leave it as is.
TakeCare
TakeCare
