Guys! I'M SANDING MY CAR! Pics and questions within...
[QUOTE=
I know clear coat is tempting but you shouldn't put it on any color that will get oxidized or take UV damage, like red. Because it will turn pink, and you won't be able to polish it! Waxing monthly is the ticket........
Just IMWO.
Either way good luck and have fun![/QUOTE]
This is simply wrong. Urethane clear, applied properly with the correct film build prevents oxidation and provides uv protection. Waxing monthly will cause an excessive build up of wax which will cause damage to a paint job. If you have a personal need to wax monthly, then the car should be cleaned first with a grease and wax remover. At the very least, waxing monthly is a waste of time.
Just IMWO.
Clear the car if you're using basecoat for a bc/cc job! Marc, you've seen my car's paint, and that's a cheap paintjob with hardly any post paint buffing!
As far as your question Chaos, if it's a single stage job, I would not apply clear coat to it. Good thing with single stage is if it gets damaged, it can be buffed out to pretty much new. Clearcoat jobs...if the clear is ruined(ie chipped, faded, etc), the car has to be re-cleared. That's the advantage with single stage paint, it's simple. The advantage of bc/cc paintjobs is that they will outlast any single stage paintjob.
For the record, single stage jobs and bc/cc jobs can both be made equality beautiful.
Captain Obvious
To snub it...remove the badge panel, then drill out the bumper shocks, prepare to be sprayed with shock oil (WARNING MESSY), push bumper in to desired location. simple.
I think the snubbed look is better suited for a darker coloured car too...the larger gap is very noticeable on my red car.
IMO after seeing the snubbed bumper vs. the euro...the euro is the closest to a turbo look an NA can get without using something like a Fiberwerks or GT Racing bumper cover replacement.
That's why I bought one. Stay tuned for my euro bumper update thread...
No where near that simple. While you could (in theory) clear over your existing paint, chances are slim that you could prep it properly without breaking through somewhere. Better to repaint it completely.
Thank you!!!
No, not Mosquito!
Guys,
For not checking this thread in 12 hours, I'm impressed on what advice has been handed to me. Paint is something I have NO experience with, so I'm listening to all of you and taking notes. So far, I think a clear coat might be for me. I can see the advantages and disadvantages, but the advantages for outweigh the bad. I plan on actually taking care of it, so the sun will not be a problem.
Thanks, Harrisonrick for your response to the snub-nose mod. I'm definitely doing it since euro bumpers are hard to come by.
::update::
I continued sanding (I took pictures, but left the camera behind and forgot to upload shots) and I have 3/4 of the car complete. I removed the taillights and found that the PO caulked the tail lights to the body to prevent leaking. I see no gasket on the tail light assembly. I took some detailed shots of the 'problem', but for the most part I scraped most of the rubbery glue off and sanded away. I'll see if the tail lights need any gasket or maybe I need a new set all together.
Mark, thanks for you offering to help with the reflector delete. I'm definitely thinking about doing it. Only problem, I have never seen a car with this mod done! Any pics? Also, I want to weld shut the antenna hole and put a 968 antenna atop the car. Do you feel like welding for me? Ha!
Thanks a lot guys, I will update with pictures after this weekend when I get the camera back.
::update::
The tailights are normally sealed to the body with a black, rubbery sealing cord. Someone may know the name of a commercially available substitute. I ended up ordering it from the dealer and got this huge roll (I can also mail you some when the time comes, let me know). It is relatively easy to clean out. I painted right to the edges of the sheet metal.
If you don't put the sealing cord on, you may have water getting behind the lenses.
FWIW I used base/clear for my car, very happy with it in all respects.
I wasn't planning on clearcoating, unless it were simple and foolproof
Marquito, sorry for the hijack
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Thread hijack over
No, not Mosquito!
amjf088, I'll take you up on that when it's time to re-seal the lenses. Thanks!
Captain Obvious
I havn't seen many 944s that DON'T have that black stuff "oozing" from the tailights. I think its an age thing.
Marc....I started my euro bumper mod thread...check it out.
No, not Mosquito!
No, not Mosquito!
Guys, do any of you have any "Body Work" links or anything you are willing to shae with me? Searching (Rennlist and Google) I have only found limited help. Ultimately, I'm trying to find the best body filler for all of my dents & dings.
Also I would like to read the advice of others: best filling method, best sanding method, which grit to end with, which paint supplier to purchase from, blah blah... etc, etc.
I'm continuing work today/tonight. More pics later when I'm finished.
Also, does anyone make a front lip for the n/a bumper? Just wondering.
Thanks!
Thanks!
