What year for the auto belt tensioner
I don't know but I would imagine it'd be tons easier to check and adjust the late 944 tension 10 times (and a whole lot cheaper.) It only takes 25-30 minutes to check/set the belt tension. Plus even with a 968 a reasonably paranoid owner will want a peek at the belts every so often anyway.
-Joel.
-Joel.
I've only compared my 968 block to an S2 block and it does look like all the same mounting holes are there. The 968 tensioner also needs the pivot lever & roller, which is a separate part, and the roller on that lever is wide for the 16v belt. I don't know if a narrow roller could be found to fit properly but it would make an interesting project. Or of course you could just run the wide roller with a narrow belt, that should be fine.
It would be cheaper to buy the arnnworx 920x or the porsche 9201 than buying a 968 tensioner setup though.
My '87 924s has the eccenytric and was mfgd. in 04/86. The 924s is reported to have the updated tensioner as per factory literature. Some obviously do not.
