944 ROADSTER CAGE!
#46
Lazer Beam Shooter
Do you have the cage welded into the joint of the firewall & windshield frame? How about into the top of the windshield? Both of those (easy for me to say) simple welds should stiffen things up a bit.
I'm not surprised that it's not TOO weak... it now probably has more rigidity to it than a 944 cab, but no reason to make it any weaker than it needs to be.
Now I want one
hmm... you should enter that into the 24hrs of lemons!
Now I want one
The 944 cabbys were beefed up quite a bit actually.
There are chassis re-inforcement plates all over the place. The floor pans were also doubled up.
If youve been in a 944 cabrio, youll find that there is surprisingly less foot space than a 944 coupe.
They loaded those things down with armor.
#48
If the cage is welded to the windshield, wouldn't it cause the windshield to crack if there is too much flex?
Now onto the good. This is f'n bad-***. I'd put a hood on it, find some way to mount some 4x4 pocket flares or some kinda flare, and run the **** out of it. If it were not for the ground clearance issues, I'd find me some mud too. Keep it up! buy far the most interesting thing I have seen on here in 3 months. Short of V2's post count that is.
#49
Having the bars across the corners off the two hoops would make getting in and out much more of a PITA. It would change from essentially being able to step in and out of it to having to sort of fall out the side.
#58
This thing is great...and you move quickly--there's an update almost every day. I'll cast another vote for more flat black, and another request for some youtube vids. Keep it up and thanks for sharing.
#60
That thing looks awesome! The front end looks alot like like a 911 slant nose. Maybe some sheetmetal to make it look like one?? in flat black of course. Looks like fun.
Makes me wanna buy one and make a sand/trail buggy out of it for driving the dirt near my house.
Wonder if Kalifornia will allow that to be street legal....I've seen dune buggies with less on the road....
