Becker Mexico Pro failure in my '92 944 s2
Hi everyone, can you help? I accidentally started my car "in gear" this evening. Had the usual little bump/surge, turned off ignition, engaged neutral and then re-started. No problem... or so I thought. My Becker unit failed to switch on automatically (with the ignition) and also won't power up from the on button. I checked the radio fuse in the 'box and also the fuse on the becker unit but both seem fine. What's happened here? Please help... thanks.:banghead:
Is there +12v supply present on the fuse wire?
Sorry, not sure (yet). Dark outside, insufficient light to do much & tools at my friend's shop!! Will be testing tmrw morning but canvassing for pointers at present. Thanks.
Problem fixed.... arghh... power was reaching the unit but it wasn't switching on. Basically, unplugged everything, checked connections, replugged the unit and hey presto.... it works. Still no idea what happened.... just glad it's now working. Thanks from Edinburgh, Scotland.
