trouble with my vacuum lines
i took my intake manifold and camshaft assembly off to clean them up and detail the engine bay, but now that im putting it back together it seems like im missing a piece, even tho i labled everthing i forgot to take pictures, all the hoses are there but they just dont seem to fit right. Its not a natural fit, like some of the hoses have forced bends in them. Does any one have a pic of an early car with the intake manifold off but the all the hoses still atached or a vacuum diagram that shows the connections.?
-Saul
-Saul
I'd recommend replacing the vac lines while your in there with aftermarket units (e.g. http://www.lindseyracing.com/mm5/mer...=944VACUUMLINE)
Here's a picture of the vac routing for a late N/A, but I'm nearly 100% certain the vac line routing is the same for early and late 8-valve 944's (excluding 951). The vac lines are the dotted ones with the things that look like small hoses at each end:
What effect does replacing the vacuum lines do? Also, Collin, do you know where I can find a diagram for a 951?
I saw this the other day: http://cgi.ebay.com/ebaymotors/ws/eB...176732833&rd=1
Think that's worth the cost?
Thanks!
Thanks!
Almost Addicted
If you have bad lines (I just did my clutch and while removing the speed/ref sensors noticed all my lines are super brittle) and you get a vacuum leak, it can cause your car to run like crap, maybe even not at all depending on the line. I am actually surprised that my cars runs so well considering the condition they are in- but when I replace them I expect it to be a bit smoother. Actually, I'm surprised my car runs at all given the mileage.
Thanks!
Thanks!
http://www.lindseyracing.com/mm5/mer...de=GENSILICONE
Which lines was the OP talking about, the small lines or the large hoses? I would be surprised if you could not get the small lines back on so they fit correctly. I could see a potential problem getting the larger hoses to fit correctly. (The diagram provided is for the small lines).
Help need to start my porsche944.
Hi guys..
I have big problem with my Porsche 944 not starting. I have change fuel pump and fuel filter. And DME relay. It's turns over for 2 second and That's it. Doesn't start. I have been trying with# easy start liquid#. Can anyone help please will be very appropriate
Amin Oxfordshire.
Amin Oxfordshire.
Hi guys..
Amin Oxfordshire.
Amin Oxfordshire.
