Custom Race Dash project w/pics
Well, I have been wanting to do this race dash project for awhile now. I finally received the fiberglass top portion today. Basically, the idea is to take a non-airbag dash, strip it down to bare metal (getting rid of all the vinyl and foam) and put on new fiberglass pieces. Here's a few pics to illustrate what I am trying to do:
The first pic shows the dash stripped of the vinyl, and the foam exposed (Anyone have any suggestions on getting this **** off?). Above it, is the Broadoot Racing Fiberglass Dash. The fitment is SUPERB! I was 100% shocked it fit as well as it did.
Pic #2 shows the fitment.
The reason I am doing this is for custom mounting of gauges, switches, etc. Not really for weight savings which their will be just a little of.
This will probably go into the 944S (depending on sale)... or the turbo track car I am thinking of building.
Originally Posted by hpservertech
Foam glued to metal? hmmmm....torch it off?
on a side note... this is what I will be installing as my new "gauge cluster"
Info on the specific model:
250-DS-UDXSR: A display only model for street rods and street machines. This model adds the features that are required on street driven vehicles, such as speedometer, odometer, high beam, parking brake and turn signal indicators. The dash also offers the ability to display water temperature, oil temperature, oil pressure, fuel level, battery voltage and tachometer. ($725.00) Approx. dimensions: 4.00" tall, 10.20" wide, 2.125" thick. (0.825" bezel + 1.30" back housing)
Total clearance required behind mounting surface: 2.0"
Originally Posted by potent951turbo86
That is going to look awesome in your car. How much wiring is needed to hook that cluster up?
Originally Posted by thoen
where is the best place to put the oil temperature sensor in a 944 na???
I'm doing a similar fiberglass dash with a DataLogger in a track only S2. Why do I need oil temp? I've installed water temp and oil pressure. What range should oil temp be within?
