RennSpeed Racing is open for business!
#31
Set to Full-Auto
Yeah, the next time I install one I plan on documenting it. It really isn't all that hard, I have just gotten good at it from doing it so many times on the NA.
#33
Herr Unmöglich
Need another part to make custom for the 44's that would be good?
How about the delrin torque tube inner bearing sleeve diagrammed in the clarks article HERE
I trying to track down a major scream in the rear end under load. Will do tranny fluid this week, but also keeping torque tube bearings in mind as the car has 155K miles on it...
#34
Awesome job Dan! My best to you. Keep the website updated with the track 951 project. I can't wait to see what you do with it. Oh, and if you remember my part request for manufacture, maybe you can squeeze it in sometime...who needs sleep anyway?
#36
Set to Full-Auto
Albert - definatly on the agenda - you'll be the first to know!
And yeah - people, I put my personal phone number on the site for a reason - to call and talk to me! If you have a part request, maintenance need, or simply a technical question..........feel free to give me a ring.
#37
Hey Dan congrats on your new endeavor, I'm wondering if you can make something for me. I need a shim or even a bushing that'll take up the gap between a late style front sway bar end and an early end.
I have an early that I put a M030 front sway bar in but the end bushings are different, I now have a 1/2" cap around the bushings that I need to fill. Could be made from aluminum, Delron, anything as long as it fills the gap and holds the bar the way it should.
Thanks,
Tom
Thanks,
Tom
#40
Set to Full-Auto
Tom - no prob, actually have the delrin in stock - all I need are dimensions.
Paul - Got your email last night and the gears in my head are already turning......
V2rocket - nope, these are identical to the original save for one dimension.
#41
Originally Posted by V2Rocket_aka944
Correct me if I'm wrong, but those cam studs look like they act as the caps on the cam cover too.
Now THAT is a neat idea, no more lost bolts under the cam :P
