Sway Bar Bracket shifting
My front sway bracket that attaches to the frame is slowly bending forward on one side. As a result the sway bar on the drivers side is slowing coming out of the eyelet at the control arm. This is a new turbo sway bar and brackets that I have had for 3 months. The old one did the same and actually fell out.
I am thinking about buying the braces that KLA sells. However, I wonder if there is an underlying problem causing this to happen. ???
i believe paragon-products sells a braket that triangulates the drop braket and would keep that from bending - however, is your swaybar upside down or something? That could also make it creep out like that. = coming out of the front bushing it should go back- then down, then back...ive seen them mounted upside down where it would go down, back then down...if that makes any sense.
Well, I bought those tranulation brackets and tried to installed them this weekend. For some reason, the brackets seem too long. If I force them in, the original sway bar bracket would no longer be perpendicular for the frame. I have the 26.8 mm bar and mounting hardware. Are you differences in the brackets with different size sway bars?
Mine took some force to get in. I put the bracket onto the swaybar droplink first but left everything loose. It then took a few taps with a hammer to get it lined up and in the cross member. I also have a 26.8mm front bar.
i wonder if the sway bar creep is a result of soft castor blocks. Ive never had this problem using 968 blocks. It would allow the a-arm to move back and forth alittle during hard cornering and work the ends off.
xboost. interesting thought. I was going to get the 968 blocks soon so I can run 18 or 19" wheels, but was holding off till I update the structs since I need to do an alignment.
