Clear turn signal lenses for 924, 944, and 944S
#62
Cottage Industry Sponsor
Originally Posted by mick944
Anyone know of(or sells) the clear turn signal lens for 968's?One of the only enhancements I would like to(or would ) make a improvement over stock on my unit.Please advise.
#63
Originally Posted by 95Juan
Nicole!-
i might have missed it, but do you have guesstimated pricing for these?
http://www.marketworks.com/StoreFron...11&i=232118507
http://www.marketworks.com/StoreFron...11&i=232118227
The S2/turbo lenses needed a more complex mold than most other lenses we make, so they ended up a bit more than I had expected initially. They and the rear turn signal segments should be here around the end of the month.
I have sent the front side markers off to my vendor, so we should have those in a few weeks as well. 924/944 US fronts are also in the works, and 968 is next.
#65
Well, I'm experiencing a major nightmare. My vendor sent me my large shipment - and forgot to put my ZIP code in the addresss... We've tried to track the package, which should not be a problem given that it has a tracking number, but DHL cannot tell us where it is.
So, we are trying to make more lenses and ship them over here through other channels - but that takes time.
944NA lenses and rear turn signal segments have already been redone, are on their way, and should be here within a week. The 951/S2 turn signal lenses will take a bit longer to remake, but I now hope to have them at the beginning of August.
On the positive, there are a few products that came with separate shipments. I have the rear side markers and the side marker housings in white and black available now.
I also have the front side markers. However, I am not 100% satisfied with the quality of the left one. There was a small flaw in our original marker that we did not see until the new lenses were cast (the clear material is unforgiving). Most would not notice it, but I want my customers to get a high quality product without a such flaw.
I sent another marker over, so new molds can be made and the lenses recast in the quality of the others (which came out really nice, BTW).
In summary: The rear marker lenses and the housings are available, the rest should become available within the next 4-5 weeks
I'm terribly sorry for the delay!!!
#68
Mexican Ambassador
are the 944 and 951 front side markers the same? seems like it to me.
oh how i eagerly await these and the turn signal lenses.
if it's august, it should be in time for a christmas present!
#69
are the 944 and 951 front side markers the same? seems like it to me. :
And boy, are those things expensive when you order them from the Porsche dealer! Strangely, we found that they cost significantly more than 928 markers - which are very similar. Can't think of any reason why that is... My pricing, however, is not tied to the original markers. I think a pair of factory markers costs more than a set of lenses and housings from my store.
On the 944/951, the housings are the same front and back, while only the lenses are different. The rear lenses are angled a little different.
oh how i eagerly await these and the turn signal lenses. :
#70
Originally Posted by PixelGrinder
Im stoked for the NA lenses! They are direct replacements right Nicole? Not the euro lenses like before?
#71
Originally Posted by MichelleJD
Do you know what the final price will be for the 951 fronts?
You can see the current pricing of all 944 lenses here:
http://www.marketworks.com/StoreFron...78036&c=794996
#72
Question for all:
If I were to offer an assembly service for the marker lights - where I fuse the lens and base together for you - how much would that be worth to you?
I'm currently not set-up to do this, but if there is enough demand I might try and find a way to offer this service. However, it would have to cover labor and materials for the process of sanding the mating surfaces, mixing and applying the glue, and fusing the pieces together properly.
#73
Are the stock pieces glued together or screwed together? (Do you have to glue on the new lenses?)
I have a feeling I'd rather glue new ones on myself so I wouldn't have to buy new housings as well as the lenses.
#74
Geaux Tigers!
Nicole,
Nice product but one question, will you offer new rubber gaskets for the side markers? Even if you have to price them seperatly I'd be in for a set. Mine are torched and per the dealer they aren't available anymore. Anyone replacing their sidemarkers with yours I'm betting most will find their gaskets in pieces.
#75
Originally Posted by ELLSSUU
Nicole,
Just for kicks - I did a little experiment with mine last weekend. I wanted them to blend as good as possible with my slate grey body color, so I painted the insides with Testors window tinting paint, and fused them with black housings. The window tinting paint is a bit more blueish than my body color, but in most lighting conditions they blend really well (the picture was taken in the sunlight where the color difference is most visible).
I also have a customer who painted them with candy apple red translucent paint for his red car (if you paint the outside make sure you put clear coat on top!!!)
This is just to give you guys some ideas... there is no limit to your own creativity.
