Clock light - 951
Clock light - 951
Does the clock have a light for night time driving, so it is visible?
If so, where is the bulb and how do I access it? I can only see the time during the day...at night it appears off
Yep, there is a bulb in there. You need to take apart that piece of the dash so that you can pull it forward enough to reach behind the clock and twist the bulb out. There are 7 screws holding that trim piece in. Two covered by the dash-end-cap by the passenger door, two under the little cover beside the passenger vent, one under the temperature sensing vent (twist it and pull out) and two under the climate controls.
Check out this link for more details: http://clarks-garage.com/shop-manual/body-08.htm
MIne was burnt out and theyre extremely hard to find. However the cig lighter has one on the side and is a perfect replacement. I stuck mine in the clock and taped it with electrical tape. Yes my clock works...who hoooo!!
Originally Posted by hockeydude
Actually, the bulb and assembly is $3.75 from pelicanparts.com.
Part # 999-631-301-90-M97
Hope that helps!
Hope that helps!
http://www.paragon-products.com/Inst...631.301.90.htm
Hope that helps!
Hope that helps!
I haven't taken the time to track another down yet.
Originally Posted by WizPorsche944
When I did It I bought a bulb that looked similar, My mistake came when I tried to get the bulb out of the holder. YOu have to replace the whole thing.
