Starter Bolts Torque
Old 09-28-2006, 11:42 AM
arbeitm
arbeitm's Avatar
Default Starter Bolts Torque
Are there any torque specs for the two 19mm bolts that connect the starter to the bell housing? I couldn't find any.
Old 09-28-2006, 12:48 PM
xsboost90
xsboost90's Avatar
tight as you can get them by hand w/a wrench- no tighter. I torque bolts till my elbow clicks.
Old 09-28-2006, 04:48 PM
Bill Lucas
Bill Lucas's Avatar
Until you fart.
Old 09-28-2006, 06:01 PM
Zero10
Zero10's Avatar
40lb/ft?
I didn't use a torque wrench on mine either, but I'd estimate that is around how tight mine are.
Old 09-28-2006, 06:10 PM
shiners780
shiners780's Avatar
Problem is, the older you get, the lower the torque value gets...
Old 09-28-2006, 06:43 PM
User 41221
User 41221's Avatar
IIRC, its 33ft-lbs, but I will check the manual later to confirm. I *just* did this, you'd think I would remember it... lol
Regards,
Old 07-23-2017, 11:17 PM
Otto Mechanic
Otto Mechanic's Avatar
11 years and the best answer so far has been "until you fart"
I found an answer on Clark's Garage, it's 32 ft./lbs. I spent the better part of half a day looking though the shop manuals and never did find this spec so I guess you take it with a grain of salt?
PS: I couldn't figure out how to get a torque wrench on the bolt that runs into the starter from the front (engine side) anyway, so just torqued until I farted...
Old 07-24-2017, 12:00 AM
MAGK944
MAGK944's Avatar
Generally if a torque spec isn't listed by a manufacturer you can use the standard metric bolt torque specs. I think those starter bolts are M12 8.8 zinc-plated. Correct me if I'm wrong.
Old 07-24-2017, 12:10 AM
edalenta
edalenta's Avatar
... or you can use the old German "gootntite" specification. I always use 55 lb-ft.
Old 07-24-2017, 12:32 AM
V2Rocket
Rainman
V2Rocket's Avatar
35 fart-pounds...LOL
Old 07-24-2017, 01:10 AM
Otto Mechanic
Mike I've already installed the bolts so I can't readily confirm the specs on them. I'm always very cautious when I'm setting steel bolts in aluminum, especially the engine block or bell housing, which is why I was looking so hard for the manufacturer spec.
They were zinc plated and I expect your recollection is correct, but as I said, the material they're threaded into is aluminum. I was OK with 40/ft. lbs. and nothing bad happened. I found the reference in Clark's after I'd installed the starter. Close barn after horse escapes...
Old 07-24-2017, 01:21 AM
Otto Mechanic
PS: The PET does list them as M12 but doesn't mention the grade. 8,8 is a pretty good bet, it's what I use when I do replacements. On the S2 one of the bolts is a little more difficult to source so I re-used both of them.
Shown as #2 and #3 in the illustration. #3 is the odd one on my car, it's actually an alen head rather than hex head. It's also not zinc as I said earlier, it's black. Looks like some sort of phosphate?
Old 07-24-2017, 12:05 PM
V2Rocket
Rainman
V2Rocket's Avatar
^^never paid attention to which model has which but i have seen plenty of cars with 1 allen bolt on the starter, presumably factory fitment.
on my car there are two hex-head bolts. maybe an early/late thing?
Old 07-24-2017, 01:24 PM
GPA951s
GPA951s's Avatar
Yup, Its a "Late" Thing... The later in life you get, the more parts you lose when you take something apart.....Then run to the store to get a Replacement "Hex" Bolt, because the original Allen types are not offered at Value Home stores...
Old 07-24-2017, 02:06 PM
Tom M'Guinn
Tom M'Guinn's Avatar
It's 48 foot pounds per the 944 S/ 944 S2/ 944 Turbo tech spec book...
Quick Reply: Starter Bolts Torque
