Steering Wheel Choices
#31
Originally Posted by arbeitm
What I really need to know is...
Do those red buttons on Alex's steering wheel fire rockets or guns?
I think he is 007, which means one is the passenger side ejection seat and the other is a bullet proof plate for the rear window
#34
Matt - dude, they're the turbo boost buttons .... aren't they ?!?!?!? ...
But seriously, is it a simple thing to adjust the wiper and cruise control switches. I'd much rather do that, if possible, then space the wheel any further out.
Alex Portanova
1989 944 N/A
1999 Chrysler 300M
1992 Harley FXSTC
Alex Portanova
1989 944 N/A
1999 Chrysler 300M
1992 Harley FXSTC
#35
As for adjusting the switches-the wiper switch is closer to the wheel than the turn signal- no idea why- just that German humor at work again I guess... The only way to adjust, that I'm aware of, is to take the wheel off & get that little nut underneath the switch plate & slide the whole thing- ALL switches will move back & forth the same amount- whole thing- on big piece- you can only move it 1/2" or so, total. I think that Matt's was just possibly slid back a tiny amount & it's either just far enough back that he misses the switch- would only take 1mm past a certain point. OR, maybe he just grips his wheel a certain way & has never had the prob? The only way to know is to measure the distance b/t the back of the wheel & the front of the switches- easy to do- I can measure mine too & we can compare- I'll try to get mine tommorrow...
The spacer idea is just the easiest way, really. The problem is, the pedals are pretty far up underneath the dash- especially clutch at full extension- IF you space the wheel, it makes the pedals feel that much further away. I made some pedal spacers w/ basic Sparco pedal covers- I wanted to get further back in the car- I'm 5'9" w/fairly long arms- the pedals were way too far down. I experimented w/various spacing- easier than I thought it would be- I have 2" on the accel, brake, & DP & 2.25" on the clutch- might be a hair much- 1.75" on all w/2" on clutch might have been perfect... Was just experimenting w/it & they've stayed on so well I've left them alone. Doesn't look as bad as the pics suggest & the DP is not actually attached in the pics- it's just sitting there- Now the wheel is at 1" & that sits me a little more upright, etc. Feels good to me. Now if I could just get the wheel a little lower... Even 1/2" would be great!
Sysgen- that makes sense...
#38
Robby - I measured both switch distances from my wheel. Of course the thickness in the wheel increases right in front of those switches. My cruise turned out to be closer...
Wiper - 6/8 inch
Cruise - 5/8 inch
I have to pull the wheel to readjust the horn contact anyway. So I'll take a look at adjusting those switches back. Other wise I'm going to get some spacers and longer bolts ready. Now if I can find a ring to space it instead of 5 indivual spacers.
As for lowering your steering wheel, get a flat bottom wheel and mount it upside down ...
Alex Portanova
1989 944 N/A
1999 Chrysler 300M
1992 Harley FXSTC
Wiper - 6/8 inch
Cruise - 5/8 inch
Alex Portanova
1989 944 N/A
1999 Chrysler 300M
1992 Harley FXSTC
#39
Originally Posted by ButtSled
This wheel (Personal Monza) makes me think of two things: LSD and Playskool. Was cheap and now dyed black.
Deano
Deano
#40
Originally Posted by Alxx Nova
Wiper - 6/8 inch
Cruise - 5/8 inch
Cruise - 5/8 inch
Alex- I meant to measure the wiper & the turn signal- not really the cruise, but that's ok to have too- it's just that I've neverheard of anyone accidentally activating the cruise- it's always the wipers. anyway, i'll get down & measure mine later, but if we can get some other measurements from people who have not spaced their wheels (since I have), we can compare your's- if Matt's wiper is 1/8" - 1/4" further back, then you'll know you might be able to space your's a tiny bit.
As for spacers, you COULD use individual spacers, but I was talking about a single space ring, like one of the following- the very last one, if you look closely, you will notice the one in my hand actually has a 5mm ring stacked w/the standard one (which is 15mm) w/longer bolts sticking through- the 5mm one is really the horn ring from my Competition- had to sand the flat surfaces to get a ground for the horn, but that was easy- anyway, you could just use one of these w/slightly longer bolts (can find places like LTB to order the bolts from) if you just want a tiny little bit of space to keep from hitting the wiper switch...
#42
Deano
Deano
#43
Originally Posted by I love porsche
matt, what does the wheel on your car look like now? i dont remember taking a good look at it, is it a thicker rim? im somewhat looking for a new steering wheel..
#44
Just measured- the circumference of the grip of my wheel ranges from ~4.25" to ~4.5"- the distance b/t the signal switch & back of wheel is 3 1/8", the wiper switch is 2 5/8", & the cruise is 2 4/8"... That's showing that I'm almost a full 2" further away than Alex's, but I only have a 1" spacer & IIRC, I tried to push the the swtichplate as far out towards the back of the wheel as possible, when doing the last spacer, as I wanted to be able to hit the signal switch easier- the 1" spacer made a world of dif... Anyway, maybe someone else could measure the stock distances to confirm...?
#45
Alex- are you sure you're not at 1 5/8" & 1 6/8" on those measurements, as opposed to 5/8" & 6/8"...? Less than 1" would be awefully close & my measurents are almost a full 2" further w/a 1" spacer, plus I slid the whole thing forward as much as possible- maybe 1/8", this would account for me being slightly less than a full 1" further than you, but instead, I'm looking at almost 2"...? anyway, just curious...
