How to Drain PS Fluid?
Mexican Ambassador
ok, so i made a dumbkoff move, and i need to drain my power steering fluid.
how do i do it?
anyone have a write up?
dumbkoff move documented here- https://rennlist.com/forums/showthre...=277997&page=3
please let me know.......soon.
how do i do it?
Legend Killer
why not just unbolt the tube below and let it drain out? Or twist off the spray cap from a windex (or similar product) and stick the straw part in and then just keep spraying the stuff out........worked for me once when I overfilled the brake reservoir.
Mexican Ambassador
what about the stuff that's already in the pump?
i assume it's some terrible mix of ATF/and regular power steering fluid.
roger- yeah, i was thinking of just unbolting the tube...
Juan isn't the only one with that same problem. Guess who else didn't look at the manual and just assumed.
BTW, it seems to run just fine with it in there. I drove it more than once with no apparent problem. I haven't driven it since I discoverd my error though.
Mexican Ambassador
yeah, that's the thing, i have no problem driving the car otherwise, and my steering problem persists, but i'm guessing i got worse with the fluid thing?
Resistance is Futile
The way I did it was to remove the belt off the pump, get a coffee can, and open up the banjo bolt and drain all possible fluid. Spin the pulley to pump out more fluid. Now would be a good time to replace the reservoir... in any case, I filled it up back up with ATF and spun the pump by hand to circulate the "cleaner" fluid, then drained again. Last time, fill it up, spin the pulley to fill and check reservoir level.
75ohm.
75ohm.
Herr Unmöglich
So I suppose you don't want to hear that it's actually 'dummkopf'?
For all your german translation needs:
Dict.Leo.Org
Dict.Leo.Org
