Chocolate Milk, Now I'm Depressed
Old 04-17-2006, 05:24 PM
yellowline
Under the Radar
yellowline's Avatar
Drain the oil and let it drain for a long period of time. I let mine sit for 2 weeks with the oil plug off until I put the seals in. No harm done.
*edit- mine didn't leak into the oil, the oil got into the coolant.
Old 04-17-2006, 05:38 PM
cjeckert
cjeckert's Avatar
Drain everthing now to prevent any corrosion and fill the crank back up w/t cheap dino oil untill you have to time fix everything, wouldnt really want that stuff just sitting in thier for a exstended period of time.
Old 04-17-2006, 05:54 PM
xsboost90
xsboost90's Avatar
i would do a compression test to see if the hg is blown. STill could be blown and show good compression though. Drain the oil, toss the filter-replace. Run a bunch of cheapo oil in there and then start, shut down and redrain. Some places will do an oil/ engine flush- the basically just run alot of oil through your motor to flush the crap out. Then start it and see if it immediately pressurizes your coolant system. If so - HG- if not i would try the oil cooler seals first.
Old 04-18-2006, 12:35 AM
Granite 944
Granite 944's Avatar
This happened to me a while back also. See my old post, and the replies I got. ESPECIALLY, Danno's reply and suggestion. I did this, it worked great, and its still going strong. Good luck.
https://rennlist.com/forums/showthre...ight=shake+oil
Old 04-18-2006, 12:50 AM
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
I would recommend pulling the head to clean out the coolant passages around the cylinders. Rod bearings may need to be redone now too.
Quick Reply: Chocolate Milk, Now I'm Depressed
