Help!! What are these resistors under the Dash?
Took my dash out and found this bracket with two round shaped high wattage resistors on a metal bracket. The wires to them showed sign of experiencing high temperature. The part numbers are: the resistors 944 616 52100 and the plate is 944 616 51100. What is the purpose of the resistors?
I believe that those resistors control the radiator fans low speed operation
Electrical current passes through the resistors and the fans operate at slow speed; also when the A/C is turned on the radiator fans are engerized in low speed. When the radiator coolant reaches a certain temperature, the electrical current bypasses these resistors and the radiator fans operate at high (full) speed.
I recently suffered a failure of one of these resistors; and it resulted in a cycling between low-high speed radiator fan operation.
