NA filter updates!!
I've found a good source for aluminum pipe and connectors.
i think I can also get discounts from K&N for the filter. Ive ordered the filter and it will be here 2 days from now. ok. basically I need to know if i get a gain from this,be it 2-10hp or if it moves power down lower,will ANYONE be interested? I also need a bansaw to cut better. an angle grinder is pretty hard to handle. :roflmao: so, any interest? |
Im very interested, Good work campeck.
1 Attachment(s)
Iv'e also been thinking of ways to play with the afm position.
and making a j-boot out of aluminum as well. looks like i'll have to have to reserve more dyno time. stupid ideas. lol worst photo shop EVER i know. but you get th idea. this would put the obstruction at the beginig of the path. making the rest of the trip easier! |
So you ended up cutting the headlight bracket off right? Is the headlight still strong enough to stay in place and be still?
no. i havent cut the bracket off yet.
i need to though! :p ill report back with that tomrow. After I get the bracket that I chopped off welded back on. |
Post removed, as I don't have a paying membership.
Originally Posted by 88BlueTSiQuest
You likely want a chop saw for the best cuts. Go to Harbor Freight and pick one up for $50, should be a heck-uv-alot cheaper than a bandsaw, and would give you nice clean chops everytime.
how about a circular box miter saw thingy. those that you pull down and it cuts wood. with the right blade it would work right?
Yes, with a 10" metal cutting blade it will be like cutting through butter. And I may be interested.
Killing posts to prove a point.
cool.
we already have a combo miter saw. Ill go get the blade in a bit. |
6 Attachment(s)
ok.
I went and got a grinder type blade. since my car is using steel until i can source aluminum (if I get gains) then I will get a carbide toothed blade. talk about sparks. holy sheisa! anyway. MUCH cleaner cuts. and now the pipes fit perfectly with each other. meaning less resistance! woo! PICS! :cool: |
oh. and my next project is definately a j-boot made out of aluminum. with grommets for the connectors.
