Remanufactured Engine Wiring Harness for 944/951
#226
Carl - I'm new to this site and have been phishing around for relevant topics, when I stumbled on to this post. I am in the process of converting my 1987 944S to an electric vehicle. As such I have the entire gas engine and its associated parts sitting in my garage. The main harness is one of those parts. Are you interested in reviewing this harness design for re-manufacturing purposes?
Thomas............
Thomas............
Carl if you make one for the S based off it I would also be interested. The 16v cars have a different harness than the NA's. (cam sensor, ignitor up by the coolant bottle, ect)
#228
Developer
Basically, if anybody want to be first, I will make the 1986-87 harness for the price of the '84-'85 harness just to get this going.
I just need somebody to order one so I can make one. I need your OEM harness to work from.
#229
Carl,
I've been trying to source a good 86 or 87 engine harness to send to you, but have not been successful. I cannot send my current harness because it's been hacked too much and I can't have the car down right now.
#230
I've been trying to locate the differences between the RHD and LHD harnesses before I obtain a US harness with the O2 sensor.
Without the o2 sensor, I'm just not going to get the results I am looking for out of my Rogue Tuning and new exhaust system
Anyone know the differences in the harnesses? Mine's an early RHD car.
#232
Developer
At this time, we have been stopped by
1) lack of availability to all the connectors we need, and
2) a good unmolested 951 harness to work from as a model.
So all we can offer is to make the 944 NA harnesses, which we do.
Here:
http://www.928motorsports.com/parts/...ng_harness.php
Here:
#233
Carl,
If you had a good, unmolested harness, how long would the delay be, for connectors, and turn around time, for the rebuilt harness?
Theoretically, of course. I realise that you can't account for every edird thing that might come up.
#234
Developer
...for a 944 NA or other?
If other (944S2 or 951) having a good model has been only part of the problem. The connectors and the shielded coaxial connections for the engine sensors have been the problems there. Can't get them, and have not found a good work-around.
We could try again, but the 951 harness was surprisingly difficult because of that shielded coax and the other connectors we have not been able to get.
#236
Freedom Enthusiast
Did you ever get a good 86 951 harness to work with? I have one that is in pretty good shape. I did modify it to work with M-tune. That modification involves just on wire cut.
You tap(don't cut) one wire on to the wire for pin 9 in the DME plug and then you cut the wire for pin 28 and connect the MAP sensor to the two cut ends.
Here is Joshua's write up on how to do the modification. It is really easy.
http://roguetuning.com/map_sensor_installation
#237
If anybody is interested, I have unmolested 89 951 harness and 85.5 NA harness cut in half. (don't ask)
#238
Oil Level Sender Connector (pigtail)
Greetings all... I am in search of a replacement for the Oil LEVEL Sender connector with perhaps 6" of wire to connect to my '91 S3 harness. The old connector seems to have divorced the wire from within. Any suggestions?
#239
Developer
I still am waiting for an unmolested used wiring harness. I have found a manufacturer that I am confident can get them made for us correctly, but we need a unmolested sample to work from.
It will be old, with cracked insulation and corrosion. That's OK. But cut, soldered, modified not OK.
I need a 944NA (early) sample, a 951 sample, and a 944S2 sample.
Let me know as soon as you find one!
#240
There's an 88 NA at a parts yard about 45 mins away from me. I'll probably be heading there in the next 2 weeks if anyone wants the harness and can paypal me for whatever it ends up being.
