A report on Odyssey battery use
Location: Albany, CA: celebrating 100 years of independence from Berkeley, CA
I thought I'd report on my experiences running a lightweight Odyssey battery for the past two months. Maybe this will be of use to someone.
This is on my 968-powered 944. The Odyssey 680 weights in at around 14lbs, compared to stock battery of ~31lbs (and that of a 968 at ~41lbs). Strictly warm climate use (SoCal) but using a really old starter that should have been replaced two years ago. The alternator is crappy, too. The car commutes 15miles each way, plus errands around town.
I killed the battery on two occasions:
* left the cabin light on overnight -- this would have given a stock battery problems as well.
* sat in the car listening to the radio for a mere ten minutes.
I would continue to use it for my daily driver, for the weight savings -- but not for roadtrips or other occasions where getting stranded would be a major pain. For colder climates, I'd say forget it (even the stock battery have problems then...).
I'm using the same battery and been using it for the last 8 months. I do live in the Bay Area where the weather is fairly warm. I've had no problems so far.
No big amp -- but I've always had issues with the stereo system draining bit too much power (can't figure out where).
So how does a battery get that fat?
