dash lights 87 924S
87 924S So it looks like my oil pressure gauge light has burned out. So at night I can not see it, does the center console have to come out to put in a new bulb?
OK,
Found this on Clark's Garage will it wor for the 924S? #9
Dan |
(Check your fuse first!) The bulb should mount in the back of the gauge, just like the others (unless updated by a PO> ) Clark's :thumbsup: Early 944 and 924S are identical dash part replacements.
Good time to upgrade all interior gauge lighting if you're pulling it all apart anyhow. Removing main gauges is easy- removing console gauges just takes time to get to. AND Fix the pesky odometer trip meter gear on the way. You will notice and appreciate brighter gauge at night driving- FWIW-- ONE brighter gauge than the others always bothered me. |
