Coolant dripping from timing belt cover?..
Originally posted by Karl2bdc
This picture isnt the greatest but it is all i have at the moment.....Cyrus you are loosening the bolt where the red arrow points roughly to correct?
My coolant always runs back over the engine, due to how it sits when i bleed the system. I have never had it run behind the timing belt cover.
If you don't believe that this is the problem, before you go spending money replacing the water pump, take the timing belt covers off, start the car, run it for awhile, shut it off and look for leaks. Do this without touching that bleeder bolt.
