How many miles you got? (prefer to see higher numbers)
#32
Jane Bond 007
275K on my N/A before the head gasket went. Didn't burn a drop of oil, bottom end is still strong. As a side note, my Exploder has 250K and all it's needed was a new tranny (due to Jiffy Lube - never, EVER, take your car to those people!).
#35
I just turned 105k, never had a problem with the engine, trans makes a little more noise than usual but still runs stromg. I'm going to do a compression test in a week or so and se if anything needs to be done. The suspension on this car is a whole nother story
#37
Hmm mine are pretty new...
951S = 119,800
84 944 Race car = ??? Guess at 140K on block
84 944 new daily driver = 79k
83 autocross car = ??? 80k at least, but not really sure (odo not working)
951S = 119,800
#42
208K on the 944 but the odo gear is broken. I am guessing somewhere around 215 or so. Daily driver year round. The oil cooler and cam box were leaking so when they were off, I had a valve job done (a while your in their repair). Replaced the power steering rack last year. Needs an oilpan gasket which I have been putting off for at least a year (it leaves a few drips of oil when parked in the driveway which is on a slight incline. No leaks on flat surfaces. The clutch was replaced by the PO in 1993 at 120K.
I imagine it will last to 500K at least.
#44
176K...never opened...ever!!!!
Strong as the day it made way its way to my moms hands (2/86)
Now its mine....but shes borrowing it again..had a feeling buying my moms car and letting her borrow it was fishy
